> For the complete documentation index, see [llms.txt](https://dev.ubidots.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://dev.ubidots.com/ubifunctions/getting-started/coding-an-ubifunction.md). Agents can also search and read this documentation through its [MCP server](https://dev.ubidots.com/~gitbook/mcp).
# Coding an UbiFunction
## Runtimes
UbiFunctions accept [NodeJS](https://nodejs.org/en/blog/release/v10.0.0/) or [Python](https://www.python.org/downloads/release/python-370/). You can use these languages to write the logic required to extract, transform, and analyze data.
## Entrypoint
Regardless of the chosen runtime, the UbiFunction must define a *main* function. This function serves as the entry point, meaning it is the first function called when a request is made to the UbiFunction.
## UbiFunction arguments
UbiFunctions require a JSON payload in the body of the HTTP request. This payload is passed to the `main` function as a dictionary object named `args`. The `args` object contains all parameters sent in the request, making them accessible within your function for further use.
For UbiFunctions configured with the **GET** method, the `args` object instead contains the **query parameters** passed in the URL.
Additionally, when an `X-Auth-Token` header is included in the request, its value is automatically injected into `args` as `args["token"]`, regardless of whether the request is made via `GET` or `POST`.
{% tabs %}
{% tab title="NodeJS" %}
```javascript
async function main(args) {
  var ubidots_token = args?.token;
  var device_label = args.device;
{% endtab %}
{% tab title="Python" %}
```python
def main(args):
    token = args.get('token', None)
    device = args.get('device', None)
{% endtab %}
{% endtabs %}
| Object       | Description        |
| `args`       | Any payload sent to the function will be contained in the `args` object.                                        |
| `args.token` | When an `x-auth-token` header is included in an HTTP invocation request, the `args.token` key will be included. |
### Behavior of the `args` object according to HTTP methods
{% tabs %}
{% tab title="GET" %}
```http
GET /prv/your_user/function_name?device=my_device&limit=10 HTTP/1.1
Host: parse.ubidots.com
X-Auth-Token: BBUS-abcdef0987654321
// Args within the UbiFunction
   "device": "my_device",
   "limit": "10",
   "token": "BBUS-abcdef0987654321"
{% endtab %}
{% tab title="POST" %}
```http
POST /prv/your_user/function_name HTTP/1.1
Content-Type: application/json
X-Auth-Token: BBFF-1234567890abcdef
  "temperature": 22.5,
  "location": "lab"
//  "temperature": 22.5,
//  "location": "lab",
//  "token": "BBFF-1234567890abcdef"
{% endtab %}
{% endtabs %}
## Code
By default, every new UbiFunction includes sample code that uses input data (`token`, `device`, and a `variable value`) to make a request to the Ubidots API. Here are the default examples for reference:
{% tabs %}
```javascript
const axios = require('axios');
// Main function - runs every time the function is executed.
// "args" is a dictionary containing both the URL params and the HTTP body (for POST requests).
  // Grab the token and device label from URL parameters, then erase them from the args dictionary
  var ubidots_token = args.token;
  delete args['token'];
  delete args['device'];
  // Use the remaining parameters as payload
  var payload = args;
  // Log the payload to the console for debugging purposes. You can access the function's logs using
  // the option in the header above.
  console.log(payload);
  // Send the payload to Ubidots
  var response = await ubidots_request(ubidots_token, device_label, payload);
  // Log Ubidots response to the console
  console.log(response);
  // Pass Ubidots' API response as the function's response
  return response;
// This function builds an HTTP POST request to Ubidots
async function ubidots_request(token, label, body) {
  let config = {
    method: 'post',
    url: 'https://industrial.api.ubidots.com/api/v1.6/devices/' + label,
    data: body,
    headers: {
      'X-Auth-Token': token
  const response = await axios.request(config);
  return response.data;
{% endtab %}
```python
import requests
import time
BASE_URL = "https://industrial.api.ubidots.com"
REQUESTS_FUNCTIONS = {"get": requests.get, "post": requests.post}
def main(args):
    if token is None or device is None:
        print("[ERROR] Please send your Ubidots token and device label in your args")
        return {"status": "error"}
    del args['token']
    del args['device']
    # Log the payload to the console for debugging purposes. You can access the function's logs using
    # the option in the header above.
    print("[INFO] Payload to send: {}".format(args))
    # Use the remaining parameters as payload
    req = update_device(device, args, token)
    # Prints the request result
    print("[INFO] Request result:")
    print(req.text)
    return {"status": "Ok", "result": req.json()}
def update_device(device, payload, token):
    updates a variable with a single dot
    url = "{}/api/v1.6/devices/{}".format(BASE_URL, device)
    headers = {"X-Auth-Token": token, "Content-Type": "application/json"}
    req = create_request(url, headers, payload, attempts=5, request_type="post")
    return req
def create_request(url, headers, data, attempts, request_type):
    Function to create a request to the server
    request_func = REQUESTS_FUNCTIONS.get(request_type)
    kwargs = {"url": url, "headers": headers}
    if request_type == "post":
        kwargs["json"] = data
    try:
        req = request_func(**kwargs)
        print("[INFO] Request result: {}".format(req.text))
        status_code = req.status_code
        time.sleep(1)
        while status_code >= 400 and attempts < 5:
            attempts += 1
            time.sleep(1)
        return req
    except Exception as e:
        print("[ERROR] There was an error with the request, details:")
        print(e)
        return None
{% endtab %}
{% endtabs %}
## Output Response
The output of a UbiFunction must be a JSON object. By default, the status code will be `200`, but this can be changed using [Raw Functions](https://dev.ubidots.com/ubifunctions/advanced/raw-functions.md).
{% tabs %}
```javascript
    return {'temperature' : 56}
{% endtab %}
```python
def main():
{% endtab %}
{% endtabs %}
# Agent Instructions
GET https://dev.ubidots.com/ubifunctions/getting-started/coding-an-ubifunction.md?ask=<question>&goal=<user_goal>
