Webhook
Definition
A private webhook plugin contains user-defined logic that is triggered by an HTTP request to its HTTPS Endpoint URL:
Required files
As stated before, any private plugin, regardless of its type, and particularly a private webhook plugin, follows the file structure shown below:
control
This is a script written in either Python or NodeJS. Think of it as a setup script, since it runs only once when the plugin is created.
function
This is a script written in either Python or NodeJS. It contains the plugin's core logic and runs every time an HTTP request is made to the plugin's HTTPS Endpoint URL.
user_code
This is written either in Python or NodeJS.
If needed, the plugin developer can let users execute custom logic. This script gives users an additional level of customization.
For instance, if a developer creates a webhook plugin to fetch data from an external API, they might want to let users further process or redirect that data without altering the core logic.
The user_code script provides that flexibility. It preserves the plugin's encapsulation while offering a dedicated space for user-specific logic.
Naming convention
You must use the names of all files and directories listed in the "Required files" section, since the plugins engine specifically looks for these files and their extensions.
For instance:
If your plugin uses Python as its runtime, the script names should be
control.py,function.py, anduser_code.pyIf your plugin uses NodeJS as its runtime, the script names should be
control.js,function.js, anduser_code.js
view.xml
This file lets the developer build and display a form that users can use to enter the parameters required by the plugin.
The contents of this form are displayed in the plugin creation modal.
For example, if we create a plugin to receive data from an LNS during device uplinks, we would need the user's LNS and Ubidots credentials. A GUI for this plugin could look like this:
This can be achieved using text fields in the form as shown below:
All of these form parameters are accessible to the function, control, and user_code scripts on each execution through the _parameters key in the incoming JSON object.
LICENSE and README.md files
Refer to the Private Plugins page for more information:
Private pluginsManifest.toml
Aside from the manifest components common to all plugin types, the following are specific to webhook plugins:
[settings]
runtime
Any valid Python or NodeJS version.
Environment in which the plugin will run.
runtime = "python:3.7"
[settings.webhook]
default_http_method
A valid HTTP method.
Default HTTP method to be used by the plugin.
default_http_method = "POST"
[settings.webhook]
allowed_http_methods
A list of valid HTTP methods.
HTTP methods allowed by the plugin.
allowed_http_methods = ["POST"]
With that in mind, a typical manifest.toml file for a private webhook plugin looks like this:
Last updated
Was this helpful?
