> For the complete documentation index, see [llms.txt](https://dev.ubidots.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://dev.ubidots.com/getting-started/technical-faqs.md).
# Technical FAQs
### How to send data to Ubidots?
Ubidots accepts [HTTP](https://docs.ubidots.com/v1.6/reference/http), [MQTT](https://docs.ubidots.com/v1.6/reference/mqtt), [TCP](https://docs.ubidots.com/v1.6/reference/tcp-udp), and [UDP](https://docs.ubidots.com/v1.6/reference/tcp-udp) payloads. To learn how to send data using each of these protocols, refer to our [Data API documentation](https://docs.ubidots.com/v1.6/reference/welcome).
{% embed url="<https://docs.ubidots.com/v1.6/reference/welcome>" %}
### Can I control a device using Ubidots?
In theory, you can program a device to act based on changes to an Ubidots variable. You can do this either by polling the cloud at regular intervals or by [subscribing to a variable using MQTT](https://docs.ubidots.com/v1.6/reference/subscribe).
In practice, we only recommend using downlink commands to push configurations to remote devices, or, put differently, to perform "virtual controls." Physical controls are technically possible, but they pose a major risk when communication fails.
See some examples of virtual versus physical controls:
| Control Type         | Examples        |
| 👍 Virtual controls  | <ul><li>Change the update frequency of a device.</li><li>Reboot a device remotely.</li><li>Command a device to download new firmware from a specific URL.</li></ul>        |
| ⚠️ Physical controls | <ul><li>Open or close a water valve. <strong>DANGER: If the "close" command is not received, a flood might occur.</strong></li><li>Start or stop a production line. <strong>DANGER: If the "start" command is received during a maintenance window, an accident might occur.</strong></li></ul> |
# Agent Instructions
GET https://dev.ubidots.com/getting-started/technical-faqs.md?ask=<question>&goal=<user_goal>
