DaaS (Decoder as a Service)
Run public code snippets from your Plugin or UbiFunction
- This feature is in beta -
The LoRaWAN ecosystem continues to grow, and so does the length of the decoders needed to transform a binary or base64 payloads, into friendly JSON ones.
Copy-pasting such decoders can get confusing for two reasones:
  • Some of them have hundreds of lines of code - and continue to grow as more sensors and features are added to the devices.
  • Most -if not all- LoRaWAN vendors offer their decoders in NodeJS, making them uncompatible if you're developing your functions in Python.
Because of this, we created a public DaaS (Decoder as a Service) endpoint:
To make use of it, make a POST request to the following:
URL
HTTP MethodURL
POST
https://functions.ubidots.com/pub/decode/custom
Headers
HeaderValue
Content-Type
application/json
x-auth-token
<your-ubidots-token>
Body
ParameterDescriptionExample
url
The public URL containing the code you wish to execute. Expects a raw text. When using Github, please set the URL to raw text mode.
"https://raw.githubusercontent.com/Seeed-Solution/TTN-Payload-Decoder/master/decoder_new-v3.js"
payload
JSON payload, containing the arguments expected by the public URL
"fPort": 1, "bytes":"SGVsbG8sIHdvcmxkIQ="
function
The internal function inside the public URL code, that you wish to target with the given payload
"decodeUplink"
Example
POST https://functions.ubidots.com/pub/decode/custom
"Content-Type": "application/json"
"x-auth-token": "BBFF-123456789"
    "url": "https://raw.githubusercontent.com/Seeed-Solution/TTN-Payload-Decoder/master/decoder_new-v3.js",
    "payload": {
        "fPort": 1,
        "bytes": "SGVsbG8sIHdvcmxkIQ="
     "function": "decodeUplink"
Last updated
