> For the complete documentation index, see [llms.txt](https://dev.ubidots.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://dev.ubidots.com/dashboards-and-widgets/html-canvas.md).
# HTML Canvas
### Introduction:
Ubidots offers off-the-shelf widgets for most visualization needs. However, some projects require more specific or fully custom widgets. For those cases, use the HTML Canvas widget to build custom visualizations with your own code.
### Definition:
HTML Canvas is a widget for building custom widgets. It lets you write custom code with the following languages, along with Ubidots built-in methods and third-party libraries described later:
* HTML
* CSS
* JavaScript
This widget features a code editor composed of three tabs, one for each language.
### When to use the HTML Canvas?
Use HTML Canvas when other widgets do not meet your functionality or styling requirements.
### How to create an HTML Canvas?
Go to a dashboard, click the *Add new widget* button (+), scroll to the *Advanced* section, and select *HTML Canvas*.
<figure><img src="/files/2dChTFxn1cYdvFTxheJB" alt="" width="375"><figcaption></figcaption></figure>
### Widget settings:
The widget offers the following settings:
* Code editor
* Third-party libraries
* Enable lazy loading
* Preload dashboard data
### Widget appearance tab:
The appearance of the widget can be customized further with these options:
* Name
* Custom Style
### Custom Style:
See [**Custom Style**](/dashboards-and-widgets/custom-ui.md) to learn how to customize your HTML Canvas styles.
# Agent Instructions
If you need additional information that is not directly available in this page, you can query the documentation dynamically by asking a question.
Perform an HTTP GET request on the current page URL with the `ask` query parameter, and the optional `goal` query parameter:
GET https://dev.ubidots.com/dashboards-and-widgets/html-canvas.md?ask=<question>&goal=<endgoal>
`goal` is optional and describes the broader end goal you are ultimately trying to accomplish on behalf of the user. GitBook uses it to tailor the answer towards what is most useful for that goal.
