Custom UI
This article goes through the Custom UI widget, its features and how to use it.
Custom UI is a Ubidots Widget that basically maps XML-like tags to web form elements, which the user can implement to create interactive web forms featuring text fields, drop-down menus, toggle buttons, among others.
Here's a quick example displaying a simple UI created with the Custom UI widget:
The following is the XML code that maps the UI displayed above:
<form>
    <paragraph type="h1">Send data form</paragraph>
    <inputcombo
        type="text"
        id="variable_label"
        label="Variable label"
        description="Choose the variable to which send data"
        placeholder="Enter the name of the variable"
    <inputcombo
        type="number"
        id="variable_value"
        label="Variable value"
        description="Set the value that you want to send"
        placeholder="Enter the value that you want to send"
        min="0"
        max="100"
    <inputcombo
        type="date"
        id="start_date"
        label="Date"
        description="Set the date in which the measuremet was performed"
        placeholder="Set the date"
    <inputcombo
        type="number.buttons"
        id="variable_value_button"
        label="Variable value button using"
        description="Set the value that you want to send using buttons"
        min="0"
        max="100"
    <inputcombo
        type="toggle"
        id="enable_device"
        label="Enable device"
        description="Set the state of the device"
    <inputcombo
        type="hour"
        id="start_hour"
        label="Start Time"
        description="Set the hour at which the measurement was performed"
    <inputcombo
        type='dropdown.list'
        id='variable_from_list'
        label="Select a variable"
        description="Select a common variable from all devices"
        placeholder='Choose an option'
       <menu>
		   <item id='temperature'>Temperature</item>
		   <item id='humidity'>Humidity</item>
		   <item id='iluminance'>Iluminance</item>
		   <item id='magnetic_flux'>Magnetic flux</item>
      </menu>
    </inputcombo>
    <inputcombo
        type='dropdown.checkbox'
        id='devices_from_list'
        label="Select multiple options"
        description="Select multiple devices to send data"
        placeholder='Choose multiple options'
        <menu>
            <item id='dev_1'>device 1</item>
            <item id='dev_2'>device 2</item>
            <item id='dev_3'>device 3</item>
            <item id='dev_4'>device 4</item>
        </menu>
    </inputcombo>
    <button type="success" click="make_request">Send</button>
</form>
Available UI Components
There are three main components that can be used within the Custom UI widget:
  • Paragraph
  • Input combo
  • Button
Custom UI elementDescriptionProperties
Input combo
Displays an input field depending on the type of property.
  • type: the type of input field
  • id: unique identifier to access this field
  • label: the text label that will be visible next to the input
  • description: small text description below the label, used to hint the user about the input
  • placeholder: placeholder text shown inside the input field
Paragraph
Displays headings/paragraphs depending on the type of property.
  • type: paragraph type
Button
Displays a button whose color depends on the type of property.
  • type: defines the button color
  • click: A user-defined label that serves as a unique ID to link the button to an action.
​The following screenshot depicts each part composing the UI displayed at the beginning of this section:
Last updated
